Hello everyone,
a long time ago I created a macro using thr app Macdorid and a webhook from ifttt to activate the opener when pressing the volume button. ifttt wants to have money for this Service.
I managed to open the opener via Swagger but the calling url doesn’t work? If I understood correctly, I had to add my “authorization” to the URL? Unfortunately I don’t know which authorization (Api) and how?
Hi Goran,
The Nuki Web API can be found under the calling URL https://api.nuki.io.
In order to make an API call from the Swagger interface, first authorize it with a client_id (i.e. client_id = OAuth2 API Key from your Nuki Web > Menu > API). Select the scopes that you would like to, and authorize.
Once it is authorized, you can try out any endpoint.
NOTE: Advanced API endpoints can only be used if you have an Advanced API request approved.
