Thank you for the answer. Would there be a way to propose an enhancement to allow for it to be disabled?
Nuki suggests connecting the power pack to a fixed source of power so I belive more people would benefit from this.
As you can see from the linked pictures below, my Nuki Smart Lock Pro 4th gen. is on continuous power and the blinking is really annoying and not aligned with any best practice. It’s I believe also impacting a bit the image of a “Pro” product.
The PowerPack is blinking while charging and stops blinking after charging is complete. If you have it permanently connected it will start to recharge once the battery percentage drops below ~75% (Link), which should take >1 month to get there. i.e. it should only blink for ~2h every month and not all the time.
If yours does not stop blinking, please contact our support via the Nuki App (Menu > Help > Contact Customer Support).
I came back today, opened the door with a key and when closing the door I noticed the blinking (which went on for probably some 10 minutes, I did not watch that long). I tried to check the battery level at that moment but instead of a percentage it was something like “retrieving” (or maybe something with “charging”).
The level is now 100%, yesterday it was at 100% as well. The lock works well and is 3 months old.
