How can I do the Pairing with NUKI FOB for the ESP32 BLE Server side?
I have a ESP32-S3-DevKitC-1 Board and a NUKI FOB. The ESP32 works as NUKI Lock Server, I have already set the follow Services and Characterisits for ESP32 Sever, to let it wokr like a NUKI Lock. the Destination is to let the ESP32 NUKI Lock Server pair with a real NUKI FOB.
I have annouced and advertised the Server with “Keyturner Pairing Service” with Characteristic(and other all Services and Characteristics in my follow code)
can you give me a example or short explanation, how to creat key pair and enable pair mode on server side to pair with a real NUKI FOB, if I press NUKI FOB Buttom 5 second?
I have already written the follow code, to realize a simple Update for value1, value2, value3 in every Charateristic and it works. just like my question, I don’t know how can I go on for “Key Pairing” now… I have also read the document “Nuki Smart Lock API V2.1 16.03.2020”, the example about “Command usage” in the document seems what I need, but I don’t know to realize it in C or C++. there is an example " Smart Lock Simulator", it works as NUKI Lock Server and with key pair, but is in Java, it is not easy for me to use it…
I look forward to some help and feedback from you, thank you very much in Advance.
#include <BLEDevice.h>
#include <BLEServer.h>
#include <BLEUtils.h>
#include <BLE2902.h>
#include "HardwareSerial.h"
#include "Arduino.h"
BLEServer* pServer = NULL;
BLECharacteristic* pKeyturnerPairingGeneralDataInputOutputCharacteristic = NULL;
BLECharacteristic* pKeyturnerGeneralDataInputOutputCharacteristic = NULL;
BLECharacteristic* pKeyturnerUserSpecificDataInputOutputCharacteristic = NULL;
bool deviceConnected = false;
bool oldDeviceConnected = false;
uint32_t value1 = 0;
uint32_t value2 = 0;
uint32_t value3 = 0;
// See the following for generating UUIDs:
// https://www.uuidgenerator.net/
#define KEYTURNER_INITIALIZATION_SERVICE_UUID                                  "a92ee000-5501-11e4-916c-0800200c9a66"
#define KEYTURNER_PAIRING_SERVICE_UUID                                         "a92ee100-5501-11e4-916c-0800200c9a66"
#define KEYTURNER_PAIRING_GENERAL_DATA_INPUT_OUTPUT_CHARACTERISTIC_UUID        "a92ee101-5501-11e4-916c-0800200c9a66"
#define KEYTURNER_SERVICE_UUID                                                 "a92ee200-5501-11e4-916c-0800200c9a66"
#define KEYTURNER_GENERAL_DATA_INPUT_OUTPUT_CHARACTERISTIC_UUID                "a92ee201-5501-11e4-916c-0800200c9a66"
#define KEYTURNER_UER_SPECIFIC_DATA_INPUT_OUTPUT_CHARACTERISTIC_UUID           "a92ee202-5501-11e4-916c-0800200c9a66"
class MyServerCallbacks: public BLEServerCallbacks {
    void onConnect(BLEServer* pServer) {
      deviceConnected = true;
    void onDisconnect(BLEServer* pServer) {
void setup() {
  Serial.begin(115200);
  // Create the BLE Device
  BLEDevice::init("ESP32");
  // Create the BLE Server
  pServer = BLEDevice::createServer();
  pServer->setCallbacks(new MyServerCallbacks());
    // Create the Keyturner Initialization Service
  BLEService *pKeyturnerInitializationService = pServer->createService(KEYTURNER_INITIALIZATION_SERVICE_UUID);
  // Create the Keyturner Pairing Service
  BLEService *pKeyturnerPairingService = pServer->createService(KEYTURNER_PAIRING_SERVICE_UUID);
  // Create the Keyturner Service
  BLEService *pKeyturnerService = pServer->createService(KEYTURNER_SERVICE_UUID);
  // Create a Keyturner Pairing General Data Input Output Characteristic
  pKeyturnerPairingGeneralDataInputOutputCharacteristic = pKeyturnerPairingService->createCharacteristic(
                      KEYTURNER_PAIRING_GENERAL_DATA_INPUT_OUTPUT_CHARACTERISTIC_UUID,
                      BLECharacteristic::PROPERTY_READ   |
                      BLECharacteristic::PROPERTY_WRITE  |
                      BLECharacteristic::PROPERTY_NOTIFY |
                      BLECharacteristic::PROPERTY_INDICATE
  // Create a Keyturner General Data Input Output Characteristic
  pKeyturnerGeneralDataInputOutputCharacteristic = pKeyturnerService->createCharacteristic(
                      KEYTURNER_GENERAL_DATA_INPUT_OUTPUT_CHARACTERISTIC_UUID,
  // Create a Keyturner User Specific Data Input Output Characteristic
  pKeyturnerUserSpecificDataInputOutputCharacteristic = pKeyturnerService->createCharacteristic(
                      KEYTURNER_UER_SPECIFIC_DATA_INPUT_OUTPUT_CHARACTERISTIC_UUID,
  // https://www.bluetooth.com/specifications/gatt/viewer?attributeXmlFile=org.bluetooth.descriptor.gatt.client_characteristic_configuration.xml
  // Create a BLE Descriptor
  pKeyturnerPairingGeneralDataInputOutputCharacteristic->addDescriptor(new BLE2902());
  pKeyturnerGeneralDataInputOutputCharacteristic->addDescriptor(new BLE2902());
  pKeyturnerUserSpecificDataInputOutputCharacteristic->addDescriptor(new BLE2902());
  // Start the service
  pKeyturnerInitializationService->start();
  pKeyturnerPairingService->start();
  pKeyturnerService->start();
  // Start advertising
  BLEAdvertising *pAdvertising = BLEDevice::getAdvertising();
  pAdvertising->addServiceUUID(KEYTURNER_INITIALIZATION_SERVICE_UUID);
  pAdvertising->addServiceUUID(KEYTURNER_PAIRING_SERVICE_UUID);
  pAdvertising->addServiceUUID(KEYTURNER_SERVICE_UUID);
  pAdvertising->setScanResponse(false);
  pAdvertising->setMinPreferred(0x0);  // set value to 0x00 to not advertise this parameter
  BLEDevice::startAdvertising();
  Serial.println("Waiting a client connection to notify...");
void loop() {
    // notify changed value
    if (deviceConnected) {
        pKeyturnerPairingGeneralDataInputOutputCharacteristic->setValue((uint8_t*)&value1, 4);
        pKeyturnerPairingGeneralDataInputOutputCharacteristic->notify();
        value1++;
        pKeyturnerGeneralDataInputOutputCharacteristic->setValue((uint8_t*)&value2, 4);
        pKeyturnerGeneralDataInputOutputCharacteristic->notify();
        value2++;
        pKeyturnerUserSpecificDataInputOutputCharacteristic->setValue((uint8_t*)&value3, 4);
        pKeyturnerUserSpecificDataInputOutputCharacteristic->notify();
        value3++;
        delay(3); // bluetooth stack will go into congestion, if too many packets are sent, in 6 hours test i was able to go as low as 3ms
    // disconnecting
    if (!deviceConnected && oldDeviceConnected) {
        delay(500); // give the bluetooth stack the chance to get things ready
        pServer->startAdvertising(); // restart advertising
        Serial.println("start advertising");
        oldDeviceConnected = deviceConnected;
    // connecting
    if (deviceConnected && !oldDeviceConnected) {
        // do stuff here on connecting
