How can I access Keypad battery status / battery warning via API?
Title: How can I access Keypad battery status / battery warning via API?
we use two Nuki Keypads at one property: one is paired with a Nuki Smart Lock and the other one is paired with a Nuki Opener.
Nuki sends us an email when a Keypad battery is running low. However, neither the Nuki app nor our Home Assistant integration shows a battery level for either Keypad. There are also no Keypad battery entities available in Home Assistant.
As Nuki is clearly able to detect the low-battery condition and send the email notification, I assume this information must be available somewhere through the API.
Is there an API endpoint, field, webhook/event, or another supported way to retrieve:
  • the current battery status/level of each paired Keypad, and
  • a clear low-battery warning including which specific Keypad is affected?
We already use the Nuki API and would like to create a reliable Home Assistant notification before the batteries are empty.
Best regards
Michael
Hi Michael,
Within the smartlock response, you’ll find a state array which contains batteryCritical, keypadBatteryCritical and doorsensorBatteryCritical. These values trigger at around 20% battery life of the respective smart lock or accessory. It’s the same conditional logic that is used to send the battery warning e-mails.
Check out the API documentation for more information on the battery charge state: General Examples | Nuki API
Kind regards,
Andrew
