Coupling your homee is done via the Nuki Bridge HTTP-API. You will need the following parameters for setup:
- IP adress of your Bridge
- Your Bridge token
In the Nuki app, you can search for your Bridge from the menu item “Manage Bridge”. By clicking on the Bridge icon, activating the API quick connection and the HTTP API, you will get the required parameters for integration.
You can then let your homee search for compatible devices and enter the appropriate values. Your Nuki Smart Lock is already connected to your homee and can be integrated it into scenes.
