Holiday Mode
Nuki Smartlock 2.0 & Opener
Holiday Mode for turning the Smartlock 720 degress under day.
I am using the night mode for the Smartlock 2. At 23h, the Lock closes 720 degrees. Under the day, the normal 360 degrees is enough.
But, when i am on holidays, the Lock should close at the maximum degrees > 720 degrees. A calendar function could be a trigger for this.
At the moment, i have to change the closing degrees from 360 to 720 manually when i am leaving under day. I think, This could be in combination with the night mode.
I think the points above is enough explanation.
