I have this Intercom from Balcom, type WS 20 and Im trying to install nuki opener with it. After some trial and error I still not able to open the front door, both by App or by ringing my apartment. Here is what I found so far
1 ring the front door as it opens
2 i guess this is the opener
3 speak/listen
4 ring the intercom when the button on the front door pressed
5 ???
While I managed to connect the yellow and green cable from the opener correctly,I still dont know where to put the black/violet cable and wich cable from the source should I connect with. I guess thats making my nuki opener rendered useless.
Cables Nuki Opener
BLUE - 1
ORANGE/RED - 2
PURPLE - 3
GREEN - 4
YELLOW - Clamp (hole 1)
Cables from Intercom
Yellow - Clamp (hole 2)
With this configuration, I am able to send signal from my Nuki App to the Nuki Opener to open the door. It works with google home and my smartwatch as well.
But one problem persist,
I still can’t use the Ring to Open function.
When someone rings the door, it still sends signal to the intercom, but Nuki Opener dont register this event and thus wont send the signal to open the door.
Does anyone can tell what can I do to fix this problem?
