I’m trying to use the hash for authentication with the bridge but authentication always fails.
Now I see there might be two problems, first according to the documentation the token should be an uint8[20], whilst my token contains characters char[20].
Second I see that the date/time on the bridge is super skewed. It starts out great, now; half a day later I check the time on the bridge (currently it’s 16:07:40) but the bridge thinks it’s 2019-04-08T13:48:48+00:00. I get the hours, UTC which is currently here -2 hours so it should say 2019-04-08T14:07:40 but it even doesn’t show that either.
Sounds like a problem with the time-update, yes. Did this happen while the bridge was online? (bc then where should be a regular fallback to check for correct time)
Would be interesting if others also experienced the same problem with too large time deviations.
O.k., that sounds quite bad; I couldn’t reproduce such delays on our testing devices while they were online though. I fear we will need some time to investigate this.
What is the timeframe a token is valid? I am seeing 401’s after one day and it seems the time is off by 30 seconds now (way better than it was before).
Hi yes, it started working again (still using the bridge online at the moment).
How does the Bridge sync the time? Via NTP or via an API call to the nuki servers?
The bridge checks for an update every 24 hours and then also checks if time is running off. There are different mechanisms to help keep time in track why even the 30 seconds in 24 hours should not happen, so I will try to recheck this again for some fine-tuning.
Great! If I decide to move the bridge to a non-internet-connected network, how would the bridge get it’s time in sync? Does it use NTP (as that network has NTP requests rerouted to my own NTP server)?
Bummer, would’ve made it easier. What IP’s/DNS does the bridge use to sync (and check for updates)? If I’d allow those from the Bridge IP only, it would still be possible to move it to my IoT VLAN
I know this thread is already quite old, but I bought my Nuki incl. bridge just recently and with the latest FW of the bridge I’m currently experiencing a similar problem. I’m using the bridge mainly in offline mode (not connected to the Internet, only connected to the local WIFI) and I’m experiencing the problem that the time of the bridge is running late, which causes problems when using hash authentication. I measured the delay and it seems the clock is running ~0,1 seconds per minute late. So after 7-8 hourse of having the bridge offline, hash authentication stops working due to the time being out of sync.
