Graphene OS and Nuki
Hello Everyone,
So I had a bit of a runaround with the support bot until a human directed me to the devforum.
That said I have had a request 866854 which received all logs from the app.
The TLDR is that the App works with Graphene OS unless you want to update devices or add new credentials to the Keypad 2.
Specifically adding totally new entries for the keypad 2.
My current workaround is that I use my old Fairphone.
Anything that opens the “Add Keypad” contexts seems to run into this issue.
So I would assume that the fix isn’t that far off to be had.
I have a coworker who is also looking forward to having this properly working.
I wondered if this is a topic that will be tackled at all.
So far Hyundai and ID Austria adopted after my requests so I am quite optimistic. :sweat_smile:
I have to add that I find this error message to be very peculiar. I assume the “precise location” does not work out as the app expects since Graphene routes it through their own infrastructure and not Googles.
That is my current guess on this issue. It isn’t as super precise but not bad in anyway.
I’ve checked out your ticket and saw that it is quite old and therefore also the App version was an older one. Basically, we were already aware of this behaviour and some improvements were implemented with the September Release.
Please update your App and in case the issue still persists, trigger the issue again and afterwards create a new support ticket with new logs.
You can also mention to support, that the issue should be forwarded to me directly.
Thanks for your cooperation!
best regards,
Zoran
