With Google home app, I have only 2 options, lock or unlock.
When I unlock it opens the door/latch.
Is this normal behaviour?
Thank you
Behavior is the same in Apple HomeKit.
If you want unlock and latch seperate you should probably look into Home Assistant.
Hello Paulo,
Unfortunately Google Home app doesn’t support “open door” and unlock unlatches the door.
As mentioned already, you could use the Home Assistant to connect the Smart Lock via MQTT and use the unlatch state.
Thank you for your replies.
Kind regards
