I’ve installed Nuki in conjunction with a number of (Nest) Google Home Hubs and am noticing the following behaviours
- Although I have only one Nuki lock with each additional usage via the home hub, the number of locks increases in the list - currently its telling me that I have 5 front door locks
- The delay between touch screen instructions on the home hub and the lock picking these up is in excess of 20 seconds
- I am able to issue a vocal command via the home hub that does not require a pin code.
