So I just got my new apartment key where I’m going to install Nuki Smart Lock (finally!). The Golmar Tekna-S GTWIN with color video is hanging in my living room and I want to check if Nuki Opener can be installed. I’ve attached a picture with the wiring, only 4 wires (technically, I guess 2 because they’re + and -) are connected to the Golmar.
The manual (Golmar) says the following:
LINE IN = Communication bus input to monitor (non-polarised).
CP = Input for calls from the apartment front door.
I’ve read the manual (Nuki) for non-supported intercoms, is this just a matter of trying it or can’t it be done? Because 4 (2) cables shouldn’t be an issue right?
Any updates on this one? Also just figured out I have the Golmar Tekna-S GTWIN. Not sure if I should just buy the Nuki Opener to try it out, hope others have done that already.
