Gira X1 + Splendid Minds app
I’m completely new in the world of API’s. I have a KNX smarthome with a Gira X1 visualisation server. Now I have found a logic block by Splendid Minds for the X1. This should enable me to open the lock through a KNX telegram. Is there anyone with experience to this, who can help me out?
Hi Edwin,
I have worked extensively with KNX systems and the Gira X1 server for quite sometime now.
The Splendid Minds logic block is quite straightforward to set up - I can help you configure the KNX telegram and ensure proper communication between your lock and the X1.
I have completed similar projects for residential and commercial clients, and would be happy to guide you through the process or handle the setup directly.
You can reach out to me on my email here
Colin
Where can you find this logic block?
