Garmin CIQ Widget to Open / lock door
Nuki Smart Lock 2.0
Implement a Garmin CIQ Widget that allows to lock and open the door with a Garmin Forerunner 645 Music Watch (and other CIQ compatible watches) using Bluetooth.
The Widget should work independent from a connected phone, i.e. Direct communication between Watch and lock via BT.
Detailed description of desired Functionality
  • Ideally same functionality as the iOS Widget, but minimum requirement is to open and lock the door
  • Secure Communication between Garmin Device and Lock
Why is this feature needed?
When I am out for a run I usually do not take my mobile phone with me, but still have to take the key with me to be able to open the door when I return. It would be cool, if I could also leave the key home and Open the door with my running watch.
  • open door with Garmin watch when I return from a run so I can leave key and mobile phone at home.
  • Open door with Garmin watch anytime it would be faster to use the watch than grabbing the phone. (I am not using geofencing).
