What addresses should be allowed on a firewall for a Nuki lock to function correctly?
Regards,
Regards,
This question is too generic, and you provided too little data, not even a lock model.
If you have set-up a WiFi connection for the lock , then IP address that is assigned to Nuki lock. Look in your router for the address. If you are using matter or hub device, then hub address probably…
