Farfasi pt5160wdg
Hi all,
do you think Nuki will work with my system (Farfasi pt5160wdg) ? For me, the most important would only be to open up remotely or automaticity open when someone rings the intercom from the gate.
Kind Regards,
Ed
Is the manufacturer called Farfisa by any chance if I only enter the model of the device here its says its compatible but I cant find any model under Farifisa that is the same as yours, but I would think they are compatible If I had time I would compare every model that nuki says is its compatible with yours, because they cant be that different yours, idk on what power does nuki opener operate but that big copper wire has me worried.
I found out that my intercom is compatible but the difference was that in my country the bought the OEM version of the intercom and branded it something completely different but I was able to find out after searching for a little bit
