Is there a way to catch a SL button press?
I would like to map my own actions and automations to it rather than using only the preconfigured ones in the app.
My use-case: as there is no way to manually activate auto-unlock I would like to use the button of the SL (which is inside the apartment) to activate a zigbee button outside the apartment to open the door by a button press.
Oh, OK. But that’s cannot be used with SL 2.0 or bridge, I assume…
Yes. Needs an IP connection directly from the Smart Lock (= Smart Lock 3 & 4 Pro or Smart Lock 4 with Remote Access via Thread).
That’s a pity.
Do you have any other ideas to realize my use-case without yet another button on the door?
Any chance that this will come to the web or bridge API knowing that you don’t share the roadmap?
A few ideas:
- Get a Nuki Fob and place it outside the door (or in your pockets) when you walk out.
- Place the Nuki Fob on the outside permanently and trigger an automation when you walk outside that enables/disables it through the Nuki Web API
- Get a Nuki Keypad and unlock via Fingerprint or Code
