I am currently looking for a way to enable or disable the opener sounds via API.
The reason for that is, that working late on the weekends result in sleeping longer into the day. As the mailmen usually just ring all the the bells in the apartment complex I always get waken up pretty early even though it is not relevant for me (old house with mail boxes inside). Hence I want to enable/disable the opener sounds depending on the sleep circle I have on the iPhone. I would be able to set up a short cut to call any API (favorably local Bridge API) to disable the opener sounds when going to bed and enabling it when I get up.
Is it possible to somehow control the Opener sounds via any API?
