Hi! Was ist mit “Obere klingel” gemeint, der Taster zum läuten oben bei der Wohnungstür, oder eine externe klingel oberhalb der Tür!?
Ja genau, die Wohnungstür oben. Es ist eine Mietwohnung.
Alles klar. Ja der hat manchmal einen eigenen Anschluss, um diesen zu identifizieren bräuchte ich aber bitte ein Foto der Schraubblöcke für die Kabel im Intercom, wo auch die zugehörigen Symbole zu sehen sind.
Ich hoffe du kannst da was erkennen, ich versuche noch mehr Bilder hochzuladen. Danke für deine Mühe!
Ok, this is a bit tricky! Comes the ring sound when someone rings from the big speaker in the Foto, or from a external bell?
It comes from the speaker thats in the picture, there is no external bell.
Hmm…
I am thinking, because the ring recognition you can surely do over one of the two Red speaker cables, but this would need a analogue configuration of the opener, but yours is digital, so I look now, if there is a analogue possibility to open the door, often possible just when connecting two of the screws, or two points of the opening circuit directly!?
Thank you for all your help, I hope that there is a workaround to do so.
No problem. Can you please show where the button for opening is on the intercom?
Sorry for the late response
The button on the right side is the one to open the door.
On the other photo you can see a black box with a little point/ button?
No problem! This button should be soldered to the board with two pins, - can you reach them!? Because if yes, it should be no problem to configure it as analogue, with all functionality there!
Hello all,
I hope someone is still within this thread and can help me.
In my new flat I got a elcom HT 802 RAB similar to the ones discussed above. But without the third cable on Position 3.
I tried to use the installation guide within the app, checked back with what you guys are suggesting but nothing works.
Attached a pictures after the opener wiring. Original cables where 6-yellow and 5-white.
What can I do to make it open the door (when ringing)?
ich habe auch eine HAT-402 und die gleiche Problematik mit dem Pfeifton.
- Tauschen von Blau und Lila funktioniert, allerdings dann kein Ring to unlock mehr
- Das Pfeifen kommt nur dann, wenn Lila an 6 angeschlossen ist.
- Verändern der Mikrofonempfindlichkeit am Gerät in der Wohnung hilft nicht, an die Anlage unten kann ich nicht dran.
Edit:
Ich glaube es funktioniert jetzt. Auf 3 war eine weiße Leitung angeschlossen, die ich nun entfernt habe. ich weiß nicht genau, wofür die 3 genau ist, in der Bedienungsanleitung steht “Etagenruf”. Sowas haben wir nicht, soweit ich weiß.
Es gibt jetzt kein Pfeifen mehr, nur ein leichtes Feedback, vielleicht kriege ich das mit dem Mikrofonregler noch etwas reduziert.
Das Entfernen der weißen Leitung hat leider doch nicht geholfen. Irgendwie war es kurzzeitig mal ok und dann ist der Ton wiedergekommen, ohne dass ich was verändert habe.
Hallo Maria,
kannst du mir sagen, wie du das Handteil geöffnet hast?
Ein Kollege hat genau dieses Handteil in seiner Wohnung und ist sich nicht sicher, wie es zu öffnen ist. Nur in eine bestimmte Richtung schieben oder muss irgendwo noch was entriegelt werden?
Oder vielleicht stolpert ja auch jemand anderes über meine Frage.
Vielen Dank schon einmal!
Shortcut: Buy HAT-402 (~60€), replace whichever HT-802 you use (~30 minutes), follow Nuki App instructions, save you the pain of trying to force fit a system that is just not compatible.
I reached out to Elcom / Hager and the customer support confirmed that HAT-402 replaces all HT-802 systems; HT Uni 2 replaces all 402 and 302 systems. I tried the HAT-402. It is very simple to upgrade the system, the default wiring remains unchanged. However, it might be necessary to replace the out station speaker (ELA-402) if it was produced in 2006 or earlier.
It is okay if you just replace one HT-802 with a HAT-402. You do not need to change all stations. As far as I can tell, it just works fine without interferences.
