I have a Nuki v4 (non Pro, running firmware version 4.5.2) and the Nuki door sensor (running firmware version 1.2.0). I have MQTT setup in Home Assistant and so I can see the Nuki and relevant device states however the door sensor firmware version and battery percentage level is not showing:
As you can see, there is an entry for doorsensorBatteryCritical but it doesnt show a percentage entry so battery critical isnt really of much use (ie I dont know what remaining battery percentage would change the value to true). Have I misconfigured this or are values just simply missing from MQTT?
Thanks @marc, sounds like I have the setup correct then.
How would I go about suggesting the enhancement to at least include percentage battery remaining for door sensor?
