Is there a way to disable (and then re-enable) auto-lock via the MQTT API?
Also, is there a way to retrieve the current state of the auto lock (enabled or disabled)?
[I’m using Nuki 4 Pro]
No, not for the time beeing.
If you want this implemented feel free to add a feature request and start collecting votes for it.
Thanks @Juergen, is there another workaround - maybe via other api?
Yes, through the web api: Swagger UI
Thanks @Juergen,
Does the Nuki bridge or Nuki Pro 4, support similar API? or is the only option to update the config is via the swagger web?
Thanks again,
Adi
Hi @Juergen,
so I decided to follow the swagger API interface - I managed to disable the auto lock feature upon request, but the problem is that the night mode overrides some of these settings.
Is there a way to control the nightmode via the api? I cannot see any configuration for whether the feature is enabled or disabled (/state shows the current nightmode status but not the configuration or whether the feature is enabled, not to mention disable it).
Thanks again,
Adi
