CORS Error - Access-Control-Allow-Origin Header Missing
I hope this message finds you well. I am writing to seek assistance with a CORS (Cross-Origin Resource Sharing) error that I’m encountering while trying to access the Nuki API.
The specific error message I’m receiving is as follows: “Access to XMLHttpRequest at ‘https://api.nuki.io/oauth2/authorize?response_type=code&client_id=9zzsaRVrchVZ18E3lt1UVQ&redirect_uri=https://dev.memoriarigorosa.com/testes/&scope=smartlock:write%20smartlock:read%20smartlock:action:log%20smartlock:action:manage%20smartlock:auth%20smartlock:state:read’ from origin ‘https://dev.memoriarigorosa.com’ has been blocked by CORS policy: No ‘Access-Control-Allow-Origin’ header is present on the requested resource.”
This error suggests that the ‘Access-Control-Allow-Origin’ header is not included in the response from the Nuki API, thereby preventing cross-origin requests from my domain ‘https://dev.memoriarigorosa.com’.
I have checked the API documentation, and it does not provide specific instructions or requirements regarding CORS. Therefore, I kindly request your assistance in resolving this issue. Could you please consider adding the necessary ‘Access-Control-Allow-Origin’ header to the API response or provide guidance on how to properly access the API from a different origin?
Thank you for your attention to this matter. I appreciate your support and look forward to hearing back from you.
Hi Sidonio,
We received your email and have requested for some clarifications in order to help you better. Will follow up on email further to resolve the issue.
