Continuous Mode it will go back to Door Mode without any action ( Opener)
Dear all,
I am experiencing already for Months the behavior that:
Continuous Mode it will go back to Door Mode without any action.
What happens:
I enable Continuous Mode but after some days I see the Opener again beeing in “door mode” or the normal mode. I dont know how many days as it was not painful enougth to do more troubleshooting.
But As I understand the “Continuous Mode” it should never go back to the “Door Mode”. Correct?
Has anyone the same issue?
kind Regards
I experience the same, I created a workaround where I have an IFTTT trigger that when the door is opened, it enables continuous mode. So each time someone opens the door it makes sure that toggle is set to continuous mode.
However, they’re discontinuing the IFTTT, and you cannot customize this setting through the API. So I’m stumped - and I rely heavily on this feature to allow guests into the building. Issuing codes using the short term rental integration is waaaay to much hassle for guests vs just buzzing your flat and using a keypad to get into the apartment…
If I find a workaround, I’ll post here. But for now I’m stumped unless they fix this bug…
