I own 2 SmartLocks V4 and use them daily but those won’t connect to my home wifi (which is a pity as I would like those to communicate with a MQTT server on that network …).
The problem is probably due to the wifi password itself as it starts with a $ sign …
This happens probably because the password is considered as a variable … which should be easily fixable by some " in the code
I’m running a lot of other devices that are connected to this wifi network, changing the password would be a real pain …
Could you please consider having a look at that and, maybe, fix it asap ?
Security is WPA2 (personal)
Error code est ‘wrong password’ (while it isn’t …)
Firmware was 4.0.36 on both device
The 2 devices are installed in different locations with exactly the same problem. The wifi networks are different (not the same access point models, not the same SSID but same password).
I just updated to 4.0.37 one for the 2 devices and the problem is still the same.
