"code" in auths is now an array instead of "string"
I am not sure what happened, but our APIs started failing because nuki’s auth list endpoint started returning an array of signed integers instead of the string (or int) as it did previously. This started happening about 4 hours ago. On web.nuki.io, we see this happening too
What happened?
Additionally, we’re getting 504 Gateway Time-out at least once a week, which is kinda unfortunate.
Hi!
Currently a maintenance is ongoing with our system and started to investigate this issue. Will get back to you regarding the fix.
We’ve managed to resolve the issue. Could you please check the auth endpoint once more?
It started working, but the fact that we’re getting Bad Gateway so often is really disappointing. Is it a known issue and will you work on resolving that issue? I know there’s a major outage now (Lots of errors when using web api or https://web.nuki.io - #4 by genesiscz) and this is the worse one yet, but they are happening every week at least once.
