Beta 2.6.5 (1430) on iOS 13.5.1, connection only via bridge at the moment (cannot test Bluetooth right now).
To reproduce:
- Select lock
- Select “Einstellungen”
- Select “Administration”
- Select “Türsensor verwalten (Beta)”
- Select “Türsensor deaktivieren” and confirm
- Spinner “Türsensor wird deaktiviert” appears and disappears
- “Möchtest du den Türsensor deines Smart Locks aktivieren?” splash screen appears (so far, so good), but
- Select “Zurück”
- Select “Türsensor verwalten (Beta)” again
Expected result: Door sensor is disabled, splash screen shows
Actual result: Door sensor is still activated, I’m back at 5.
