I just tested this here with FW 1.12.6 and 2.2.9 and couldn’t reproduce the problem with using /callback/remove on ID=0 or ID=1 if 3 callbacks were set.
Could you check your FW versions and give me a step-by-step description of your API-calls?
Regarding the API calls, I was manually adding 3 callbacks by opening the URL in the browser. Then listing them and finally removing ID 1 (calling the URL in the browser).
I developed an adapter for an IoT plattform which reads the callbacks and offers the possibility to delete it.
If a user deletes the callback with a certain ID, it might remove the wrong callback, if the callbacks themselves have been in the mean time by any other source.
Eventually, this leads to wrong behavior because the ID itself is not unique.
My implementation had no verification if the URL was added before already because I thought the Nuki bridge does that. Thus, the same callback URL got added multiple times. On the software bridge this does not happen.
Additionally, the Bridge API documentation (https://developer.nuki.io/page/nuki-bridge-http-api-190/4/#heading--bridge-discovery) states for the action /unpair, that it is not available on software bridges. For me the actions /auth and /configAuth are also not available. Is this a bug on the software bridge or a lack in the documentation?
Finally, the software bridge does not broadcast ip or port (but its ID) to https://api.nuki.io/discover/bridges. A note regarding this in the docs would also be helpful.
