Callback question
I’m trying to script my own version of Nuki support into OpenHAB without using the OpenHAB Nuki Binding as its not proving reliable and I have a question about callback.
According to the documentation
 The new lock state will be sent to the callback url by executing a POST request and posting a JSON list in the following format:
{“nukiId”: 11, “deviceType”: 0, “mode”: 2, “state”: 1, “stateName”: “locked”, “batteryCritical”: false}
I’ve created a string Item “NukiCallbackTest” in OpenHAB and added the following callback.
 http://OpenHABServer/rest/items/NukiCallbackTest
the link at http://myNukiBridge:8080/callback/list
takes me to the item in OpenHAB, but the item doesn’t receive any updates
What am I missing?
Hi Kevin!
I am not sure how the callbacks are handled in OpenHAB. Does the URL listen to POST requests?
wbr,
Stephan
The URL I’ve set is the individual item in the REST interface, so a post to the callback address I’ve set is the same as updating the item from within openhab.
Items can be changed directly via the REST interface. The item always remains blank
What you could try to find the cause would be:
EDIT: I moved this topic to Bridge HTTP-API
Have a look here - GitHub - sumnerboy12/nukiproxy: A simple proxy to sit between the Nuki bridge and openHAB (since the openHAB REST API requires `Content-Type=text/plain` but Nuki sends `application/json`). I had a similar problem and solved it with this little proxy server. I have since updated this locally to use MQTT rather than direct connection to openHAB but the principle is the same.
Hope this helps.
Thanks Ben, are you happy with your MQTT solution? I haven’t looked into this further other than creating a rule that mainly works around the problem. I only use the OpenHAB Nuki binding for state updates and I ignore the lock state when making locking decisions. I’ve also stopped querying the lock from a rule as the bridge seems to get stroppy if it receives more than one query at once.
Yes relatively happy. I do seem to miss the odd event, but I think this is likely down to the bluetooth connection between the lock/bridge. Not 100% reliable unfortunately. But sending lock/unlock requests seem very reliable.
Same here too, I’m not receiving any callbacks anymore either. Looking at the log and there’s nothing mentioning a callback either.
"firmwareVersion": "2.5.2",
"wifiFirmwareVersion": "2.1.17"
