Calibration of the Nuki 3Pro manually
I would like to be able to adjust the calibration of the Nuki 3Pro manually.
I want it to close with the correct key position as if using the key and then open with the correct key position as is done with other brands.
Turning manually and telling the Nuki closed position and the same with the open position.
There is only the option of auto calibration or long or short calibration.
The manual calibration version does not exist, there is only the option of % in degrees, that is inaccurate or you go too far or not at all.
Would it be possible to do it somehow or add the option?
Thank you.
If you want to see this implemented feel free to add a feature request and start collecting votes for it.
