Today I bought the Nuki Opener in white. According to the compatibility list from Nuki, my Busch Jäger system should work with it. Unfortunately, I’m now standing for hours at the busch jäger door opener and try unsuccessfully to connect both.
According to the app, I should remove the cables from B1 (BROWN), connect them with the Wago clamp and the yellow or red cables. The remaining cables (black, orange, blue, purple and green) should be in the slot B1.
I connected everything as described.
In setup everything is working as expected (except ring-to-open ofcourse), when ringing the doorbell nuki will recognize it and go one step further in the setup, but when all is set up the opener won’t recognize any ring any more. Does anyone know what might be wrong?
After some troubleshooting I now connected RED to A1 and BLACK to B1 and the other NUKI cables are in the clamp, so not connected.
I successfully added the Opener to my Home but without Ring-to-open. In the installation step when Ring-to-open is tested by NUKI it won’t open the door, but I just clicked on „Yes“ so the installation process gets completed.
Really bad performance from NUKI that there is still no support.
I have tried the red A1 and black B1 solution but it doesnt work.
With some struggles I get further in the set up bit then receive a big X and the information that my system wouldn’t be compatible. @miwo or @cschmitt2107 could you share your final wiring please?
