I am using the Opener and Bridge. I am using the Bridge API together with homebridge-nuki to expose the opener to HomeKit. This was working fine until this morning when i updated the firmware of the opener. After the update it seems the ‘name’ field for the opener is an empty string when calling /list. When I call /info it has a name for the opener.
/list:
[{"deviceType": 2, "nukiId": *redacted*, "name": "", "firmwareVersion": "1.5.3", "lastKnownState": {"mode": 2, "state": 1, "stateName": "online", "batteryCritical": false, "ringactionTimestamp": "2020-10-13T11:37:59+00:00", "ringactionState": false, "timestamp": "2020-10-13T11:37:59+00:00"}}]
/info
{"bridgeType": 1, "ids": {"hardwareId": *redacted*, "serverId": *redacted*}, "versions": {"firmwareVersion": "2.7.0", "wifiFirmwareVersion": "2.1.17"}, "uptime": 1337, "currentTime": "2020-10-13T11:58:16+00:00", "wlanConnected": true, "serverConnected": true, "scanResults": [{"deviceType": 2, "nukiId": *redacted*, "name": "Nuki_Opener_1B7A141A", "rssi": -51, "paired": true}]}
I have tried renaming the opener via the iOS app and have also deleted the opener from the app and re-added it. Both did not change the field being empty. Unfortunately the home bridge code relies on the name field being present so this breaks it completely.
Any ideas on what i could try?
Jenni
