Battery pack (1st gen) "refurb" with Eneloop pro?
Hi, I’m using a Smartlock Pro v3 (wifi) and my power pack only lasts a few days (I’ve got a second power pack for comparison which works OK, though it doesn’t last as long as it used to).
In my old “1st gen” power pack, I see that the included batteries are 4x AA 1.2v rechargeable NiMh : can I replace them with Eneloop Pro which seem to have about the same specs ?
Thanks for your help
Best regards
Hi Anthony,
i did this a year ago with my battery pack. Better use the the normal white eneloops. The black ones have high power support, but they have a higher self discharge.
My battery pack works great with this retrofit.
Best regards!
Micha
Hi Micha,
That’s good news, thanks for the advice regarding the “normal” white Eneloop vs “pro” black Eneloop
I will try this soon
Cheers
Be careful with the charging. The charging electronics cut-off points are not adjusted for Eneloop batteries, which can result in not charging, not fully charging or not stopping to charge. This should not be dangerous and not harm the batteries, but i would certainly not permanently power such a modified power pack.
Hello Jurgen, I also changed the 2 years old exhausted batteries of my Nuki v3 battery pack with 4 new Panasonic Eneloop (white ones, not pro). Now I’m really satisfied of the battery endurance, but the batteries doesn’t charge inside Nuki: when I connect power usb cable the led does not flash but remains steady-on. I have to extract the Eneloop batteries and charge them separately. Is there any third party AA battery (with high capacity, possibly around 2500mAh) that can be charged inside Nuki? Maybe I have to insert the Eneloop Pro (black ones)?
Thanks a lot.
Cheers
As mentioned above the charging electronics are not made for Eneloops therefore i can not comment on this. One thing to note is that the PowerPack will not charge as long as the batteries do not fall below a certain threshold (~80%). This is of course also valid for Eneloops and this threshold might be lower for them. So make sure that your Eneloops are quite empty before you try to charge them.
Thanks @Juergen.
I’ve 2 power packs and one of them started to behave strangely (year 2021): when i insert it, after charge, the Nuki Pro 3.0 starts blinking white and keeps trying to close the lock. Non stop. Probably batteries are gone, ‘cos the other battery pack still works fine (but my pack always lasts no more than 20 days).
Can i try changing my batteries with white Eneloops, or would you suggest another model? Thanks
Ciao @DermitderBahnfaehrt do your Eneloop’s charge regularly within the battery pack (without charging them outside)? I see from another user (@Diego_Maggioni) that he has to charge them outside.
Thanks and have a great 2025!
Ciao Gianluca, I inform you that I bought Eneloop pro batteries (the black ones) to check if they charge inside my Nuki V3 as the white ones don’t.
Unfortunately also Eneloop Pro do not charge inside Nuki, I have tried at 60% of charge without success.
