Same problem here. First iPhone works without problems. The second don‘t…
Same for me here - any update on a fix?
Is there already a fix for this? I have the same problem
For those still looking for solution:
The problem is that you added another phone via invitation code (not by Bluetooth directly). You can check it - go into Bluetooth settings and try to connect to Nuki. Phone on which Auto Unlock works will connect, the second one will fail.
How to fix?
On the second phone, remove the nuki device in the app.
Then re-add it in the app by Bluetooth - go near the lock, hold the button for 5 seconds and voila. Now set up Auto Unlock and it will work. (example: now go into Bluetooth settings and it will connect to Nuki with no problems)
Solved it for me
Thx, for me too.
Just for clarification: Did you use an Android or iOS phone as “2nd phone”?
Both android
