For which NUKI product do you want to submit a feature request? Smart Lock
When I enter my house via the backdoor (without smart-lock) my front-door will open. That is not diserable! So I cannot use the geofencing option.
In order to be able to use the geofencing option I would like the app the sound an audible question : You are apporaching < door name> . Would you like to open it? Also the app should listen to my answer. If I answer Yes it will open the door. If no, it will continue to see if I am approaching an other door and it should ask me to open that other door.
Why is this feature needed?
I cannot use the geofencing Open door functioanlity when entering the house via backdoor without smart-lock.
See Above
See above. Also important: It should react to my answer!!! I should not need to grab my phone and press a Yes or No button as this would render the geofencing functionality useless. Maybe you could make this work with Google Home assistant.
