Sorry to hear that you have new issues with the updated version.
Could you please provide us your logs by contacting our customer support via the app and furthermore I’d like to know if you triggered the action while the Watch was in standalone mode or if your phone was nearby as well?
Ja, das stimmt, nach der Neuinstallation funktioniert es einmalig.
Auch heute, nach dem neuesten Firmware-Update, funktioniert es einmalig, aber danach stürzt die Nuki-App immer ab, wenn ich versuche, das Schloss zu öffnen. Ich muss die App auf der Apple Watch schließen und erneut öffnen, um das Schloss schließlich öffnen zu können.
Auch nach der Installation der neuesten iPhone- und Apple Watch-Software gibt es keine Verbesserung.
Dieses Problem besteht bei mir bereits seit über zwei Monaten, es wird langsam Zeit für eine Lösung, finde ich.
as mentioned before, please create a support ticket in the app via Side Menu → Help → Contact customer support so that we gather the internal logs and check out what’s the issue on your end
For me it is fixed with the latest App version : 2026.2.2 (2721) from 12-02-2026.
Now it is working as it should without a second attempt.
It takes some multiple helpdesk tickets but WE solved it
Great job.
It had been working quite nicely since the mid Jan. beta. But for some days now, it’s back to 2 or sometimes more tries before the door will open. Also, now every few days the iPhone will notify me that the App has crashed.
After working at least with multiple button presses since Dec, it’s now once more not working at all. Button will re-enable after a few seconds. Gave up after trying 5x or so. As always, when switching to iPhone widget, door will open immediately. watchOS 26.4, iOS 26.4.1, Gen 2., FW 2.15.3, App 2026.4.1 (2729).
if you have reported this to support already via Side Menu → Help → Contact customer support please forward me your ticket number via DM, since we’re currently investigating reported issues in order to provide a solution as soon as possible
if you’ve not done so, I’d kindly ask you to do it as we need the device logs which are provided by following the steps above
thanks for your understanding and help in order to resolve the current issues with Apple Watches
Ich habe auch wieder Probleme mit der Nuki App für die Apple Watch.
Wenn ich manchmal nur das App-Symbol auf der Uhr antippe, öffnet sich plötzlich die Tür obwohl ich noch gar nichts ausgewählt habe.
Das ist wirklich sehr unbefriedigend. Momentan nutze ich Apple Kurzbefehle um die Tür zu öffnen. Die Nuki AppleWatch-App ist mir da zu unsicher.
