At this point your email address should be displayed.
Does your email address contain any special characters or do you use the two-step verification for your Nuki Web account?
I implemented the integration with ioBroker and the nuki-addon. The activivy logs lacks the name too: “Nuki Web ()”. Maybe the integration does something wrong here? I assumed that the problem resulted from the “unknow”-Entry under the notifications.
@creak The name in the brackets is the name of the integration description (string, optional) (from Swagger UI model)
If it is not set it is shown with the empty brackets as in your screenshot.
Do you have other integrations running where you see a correct name? That would clearly hint, that it is missing in this ioBroker integration and not an error on our side.
Night Mode: from feature point of view ok, but we can’t use it as our door locks quite difficult between 360–> 720 degree. Therefore we have set in normal operations, to protect the Nuki, to lock only up to 360 degree. Once that becomes available as a choice for NIght Mode, we would use it.
I’ve just tried the shortcuts feature. One door won’t unlock and throws “A connection error occurred” message. The other one locks ok, but unlock makes it run to the end stop everytime. A unlock from the app doesn’t do this.
Somehow shortcuts aren’t working for me. I’ve activated the feature in the nuki app beta, but the shortcuts app doesn’t show any nuki related actions (no “nuki” under apps and searching for it also yields no results).
Please also check if all permissions for the Nuki App are activated under 'Settings > Siri & Search‘.
In the Shortcuts app, commands and apps are often only displayed after they have been used several times - so you probably have to execute some lock actions with the Nuki app before they are displayed in the Shortcuts app.
