App Update: Nuki Android App 2025.11.1-beta
We released a new Android App version!
What’s new?
2025.11.1-Beta (1216), 30.10.2025
  • The app now unlocks and locks your door even faster when you are nearby.
  • Fixed an issue with displaying battery warnings even though batteries were loaded.
  • Further performance optimizations and bug fixes.
2025.11.1-Beta (1226), 12.11.2025
  • Fixed an issue where in some occassions remote access was not established properly.
Can confirm that the erroneous battery empty warnings were fixed for the Smartlock Ultra. Thanks!
For some reason it destroyed remote acces for all my devices
Yes, can confirm the bug. I am unable to access my Smartlock Ultra remotely through, while this worked flawlessly before.
Actually: how do I revert back to a stable Nuki app version without losing access to all my locks in the app? Some locks have been shared with me and I don’t have physical access to them. @Zoran
No issues here:
Nuki Ultra (Matter over Thread), Aeotec Smart Home Hub 2 (NAT64), 2025.11.1-Beta.
I think it would be helpful to mention what devices and how they are connected…
Last night there was a minor update coming in from Google Play (500 kB) that didn’t change the version number, but fixed the remote WiFi connection issues with my Smartlock Ultra and the Smartlock 3 Pro
I have the same issue, no remote access via app, after the Update.
Only via Nuki Web it’s working.
2 smart lock pro matter connection
1 smart lock 2 via nuki bridge…
Looks it’s stable again at the moment :crossed_fingers:
which SL generation are you using?
and does the remote access work in general (aka is it just a displaying issue or a “no remote access possible” issue)?
Nuki Bridge
Nuki Opener
Nuki Smartlock 2.0
No remote access via app aufer update.
Open via Nuki Web at PC is working.
Via Bluetooth also accessable.
I reached out to you via DM with further instructions, to get more insights!
Hello
Same Here.
Smart lock pro 5th Generation
Firmware: 5.5.10
Nuki Android App: 2025.11.1
Remote Access does Not Work any longer.
Tried the steps described in the Help page (integrated WLAN changed to compatibility mode, restart of the smart lock etc.)
Connection Status ist yellow
At Home I started the Firmware Update process. An Error occurs and says “for checking for a new Version an active Internet Connection ist needed”.
But Internet Connection ist available.
could you please provide your App logs via “Menu → Help → Contact customer support” and please write in the ticket that it should be forwarded to me directly?
that would help us to check out what’s happening in your case, as it occurs only sporadically
I opened a Ticket #699293.
Ist it possible that the Connection requires now a Port forwarding? The Help Pages say that the nuki App establish a Connection via TCP 443, so generally No Port forwarding is necessary.
In Addition: after establishing a VPN Connection to my Home Network, the Nuki App worked fine again.
But without VPN and directly via Mobile Network noch Connection could be established.
thanks for the ticket number, we’ll check out your logs to understand what’s happening!
according your findings: no, it is not the case that port forwarding or VPN is needed.
Update: we found the root cause of the issue and will provide an update as soon as possible!
thanks to everyone who provided us their App logs!
That is great. Could you please Detail the root cause? Is there a workaround as long as the fix is not deployed?
I won’t go into too much detail, but there are basically some edge cases which run into remote-connection issues.
A possible workaround you could try out: open the Connection Status of an affected device and wait until it updates the status.
if that also doesn’t work, you can either re-install the App via the Play Store or wait for the update
UPDATE: the initial post has been updated with the information to the hotfix version 2025.11.1 (1226)
sorry for the inconvenience and thanks for your patience
