Hi, I’m having an issue with this beta build.
Trying to add Bridge on Samsung S20 Ultra (running Android 10) always shows no networks, so I cannot finish the initial setup. Bridge itself is evenly flashing LED telling me it is in correct Maintenance mode immediately after I plug it in the power socket.
I’ve searched the forums before I wrote here and double checked all possible causes.
I am using a 2.4 GHz network, I did try with other networks and other devices.
But all with the same result.
Bluetooth connection works, but when I get to choose a network, none are shown.
If I try to manually add my network via Other… it results in Error code 10.
I looked into logs on my device and can see some SEVERE errors flagged.
From a professional standpoint, this might be related to Android 10 WiFi classes deprecation, but as a new user, I’d really like to help out and resolve this issues.
I can provide extensive logs, videos and detailed descriptions of current setup and devices.
P.S. Just tested this at work on iOS and Android 9 devices. Same result of no networks found around device or Bridge.
I can only point a finger at the Bridge itself to be blamed for this issue.
Hi Bojan,
thanks for reaching out. This is a development related forum. Please get in touch with our support via https://nuki.io/en/support-request/ or at contact@nuki.io. Provide all data you have. Thank you!
