Nuki Ultra Lock US Version
Home Assistant 2026.4 is releasing an option to allow control of the lock via a Manage Lock option. Through some discovery, this is not enabled in the lock via the firmware so it is not available in Home Assistant.
Enable management via Matter
To allow more functionality via Matter. This explains it better:
NOTE: This version goes live April 1st but is available publicly early as part of their beta program.
Assign temporary access to users via Home Assistant for example. From their page:
On the device page of your Matter lock, you’ll find a new Manage lock option. It opens a dialog where you can see all configured users, add new ones, edit existing ones, or remove them. When adding a new user, you give them a name, set a PIN code, and choose an access type: full access (can lock and unlock anytime) or one-time access (the code works once and is then automatically deleted by the lock).
