Adjusting Locking Speed via MQTT
Hello everyone,
I would like to know if there is a way to adjust the locking speed of my Nuki Smart Lock Ultra via MQTT. Specifically, I’d like to activate Gentle Mode between 12:00–14:00 and 19:00–08:00.
I couldn’t find any related options in the MQTT API. Is there any way to achieve this via MQTT? If not, could this potentially be done using the Bluetooth API? I did find relevant commands there.
In the app, this can be set for the evening via Night Mode. Thanks for your support!
This is not part of the MQTT API, but is possible using the Bluetooth API. You can use NukiHub (GitHub - technyon/nuki_hub: Use an ESP32 as a Hub between a NUKI Lock and your smarthome.) as a complete solution that acts as a bridge between MQTT and the bluetooth API.
