Adding missing information on your documents
For your documentation on Web API Example: Manage PIN-Codes for your Nuki Keypad
Complete all the necessary information you need for the api
Under “Create new pin” is some information missing. Actually you write " You have to set a PIN_NAME (string; up to 20 characters) and a PIN_CODE (6 digits from 1-9; not starting with ‘12’)."
However, correct and complete would be: " You have to set a PIN_NAME (string; up to 20 characters) and a PIN_CODE (6 digits from 1-9 without 0 (zero); not starting with ‘12’ AND not allready used by another PIN_NAME (each PIN may only occur once in the system!)."
Because it is a relavant information about the handling of the api and the nuki product respectively. And it is still missing.
Thanks for the input. I have updated it accordingly.
wbr,
Stephan
