Add setting to keep door unlocked
Nuki 2.0
Add a setting to stop autolock when closing door, either via gesture 1x press on lock button, 2x press on lock button or Nuki action the same way as lock/unlock/lockngo.
Add a setting to stop autolock when closing door, either via gesture 1x press on lock button, 2x press on lock button or Nuki action the same way as lock/unlock/lockngo. So that you can close door when using door sensor and it won’t autolock. And then you can reactivate the previous behavior when e.g locking manually or locking via action
Because there is no setting when using door sensor, so this would really be useful when for instance when having guests over at short intervals then it would be bad that the lock would autolock the whole time and would use a lot more power and drain batteries quicker
When having friends over the lock would auto lock when closing door everytime more people would enter the home, so being able to press a action keep door unlocked and then you would just lock the door either when every one has left or last person would leave. And this would also let batteries last a lot longer.
Yes, I agree, pausing AutoLock is a missing feature. Maybe also to add it to the app, “Pause AutoLock” and “Resume AutoLock”.
The same goes for “Lock’n Go”, should be paused if AutoLock is paused
