It would be very helpful to activate the night mode over the bridge http api and not only by a configured time. So that it is possible to integrate it into home automation routine.
Why not just lock the door via Home Assistant? If you also want auto-lock, you can add a second automation that locks after x time on unlock, restricted to night hours
I do that at the moment.
But the night mode does not only lock the door.
During the night mode is enabled a auto unlock will be declined and the power consumption is less.
Can those settings be set via the API? Arguably this would be a lot simpler to do with a single command… perhaps the custom nuki integration can add a service for night mode…
