Hey there,
Looking to hook up the Opener to my analogue intercom. My intercom has the following cabling:
Tech install PDF can be found here: https://www.tektone.com/pdf_files/manuals/IL826_PK543A_install.pdf
Any ideas?
Hey there,
Any ideas?
Hi! Have you found out anything in the meantime?
I haven’t. Most of the connections I attempt, the Nuki will unlock the building door regardless if my apartment buzzer was pressed - which is not what I’m after!
Not sure if Nuki wants to pounce on this but an NYC startup is about to release something similar to the Nuki Opener that is compatible with US intercoms (like mine). Though they charge a monthly fee for the same features as Nuki!
Blue and purple on 2 and 3 for opening, you tried already? What exactly is the behaviour, when you connect blue and purple to it?
