Switch with ring
Hey,
I have a normal switch (thats works fine wit “other door” or “generic analoge”) and a extern ring.
I want that the ring bell is still connected (worked with nello all the time).
With “other door” I am not able to change the "ring wire connected to yes, so I have to take the other way.
And it is working, if I connect the ring wire to yellow or green but it is also detecting extra ring bell actions like every 20-30 secs.
Anyone knows how to fix that?
Hi, I got the same problem.
Did you found a solution ?
