Q: My Smart Lock 3.0 is having issues with the stability of the WiFi / MQTT connection - What can I do?
Most WIFi and MQTT related problems origin from the power saving that the Nuki Smart Locks have to apply and use in order to achieve a certain lifetime based on the 4xAA batteries while being fully connected and online.
Therefore, most of the issues do not rely only on the Nuki Smart Lock but also on the given network infrastructure and settings. To check if generally a stable connection is possible we suggest to adapt the WiFi power saving of the Nuki Smart Lock and observe the stability.
With the recent firmware you can change the aggressiveness of the WiFi power saving by setting Smart Lock > Settings > Features & Configuration > Battery > Energy-saving mode to “FAST”. This will deactivate all power saving options and should provide you the best possible user experience while also draining the most power from the batteries.
If this works out nicely, you can then set the Energy-saving mode to “MEDIUM” to get the stability and power drain more into balance.
If you do not have problems anymore set it back to “AUTOMATIC”, which will use an automatic mechanism to balance between stability and power consumption. This is the standard setting and usually the best choice.
Q: How does the Smart Lock (4th & 5th Gen) switch between WiFi and Matter? Is there any option in the Nuki App to enforce one path?
The current mechanic is as following:
If Matter & WiFi are both enabled, the Smart Lock evaluates while it boots if it can get online via Thread. If the remote access connection via Thread is not available within 60s it uses WiFi.
If it is on Thread and Thread becomes unavailable it does not automatically switch back to WiFi.
The Thread connection is only available as soon as the Smart Lock is paired to a Matter hub, it is not planned to support Matter via WiFi.
You can force to always connect via WiFi by turning off Remote Access via Thread via the Matter settings in the Nuki App.
You can force to always connect via Thread by turning off WiFi via the Nuki App.
You can disable any attempts to connect to Nuki servers by turning off WiFi and Remote Access via Thread via the Matter settings in the Nuki App.
Q: My Smart Lock does not pull the latch so that i can not enter from the outside. What should i do?
For doors with exterior knobs or bars, Smart Lock settings must be set properly to retract the latch for most default actions (e.g. Auto-Unlock, unlocking with a Keypad).
Ensure you choose the appropriate door fitting type in the Smart Lock settings:
Q: My Smart Lock Pro (4th generation)/Ultra struggles to keep the WiFi connection steadily online. What should I do?
Make sure your Smart Locks firmware is updated to at least Beta 4.4.4 or higher and that you have the latest version of the Nuki App on your phone. On the WiFi settings screen you have two options to change the WiFi power saving settings:
1.) WiFi Modes
“Automatic”
This mode is enabled by default by the Nuki App, designed to provide the optimal balance between battery life, response time, and WiFi stability. The WiFi-related settings remain consistent with previous beta versions.
“Compatibility”
This mode can be manually enabled through the Nuki App and is primarily intended for situations where the Smart Lock Pro cannot establish or maintain a stable WiFi connection. As the focus of this mode is ensuring maximum compatibility, it results in increased power consumption and should therefore be used with caution.
In case the above mentioned modes are not sufficient to achieve a stable WiFi connection there is also the possibility to manually adjust internal WiFi related settings.
Enter the “Built-in Wi-Fi” screen (via Settings > Features & Configuration > Built-in Wi-Fi)
Tap 7x onto the NETWORK to display the hidden information and settings
Adjust the settings according to your requirements
List of adjustable settings
Broadcastfilter: This defines how broadcasts are handled by the Smart Lock Pro. The more packages are let through the more often the Smart Lock wakes up and the more battery power is drained. Some routers require that the Smart Lock responds to some broadcasts (e.g. ARP requests), therefore turning it to medium or off can increase the compatibility. Warning: This can have a major impact on battery life in some networks.
DTIM skip interval: The DTIM interval of your network is defined by your WiFi router and defines how often the Smart Lock wakes up to listen for WiFi data packages. Skipping intervals saves power, but increases the latency. Set it to router skip rate in order to not skip any wake ups and increase the compatibility. Turning it off is not recommended, but maximizes the Smart Locks response time (latency). If you can change the DTIM interval in your WiFi routers settings, we suggest to set it to 3.
Server signal skip: This setting defines how often keep alive signals are sent between the Smart Lock Pro and the Nuki server from 60s to 5min. The more frequent the Smart Lock Pro wakes up and sends data, the more battery power is drained, but the faster a corrupt connection is detected and reestablished. Turning it off can increase the compatibility in some cases.
Power Saving Mode: Allows to choose the highest power saving mode the integrated WiFi module tries to apply. It supports Performance (UAPSD) and Power saving (FAST-PS). If the WiFi network does not support a certain power saving strategy it will fall back to the lower one. FAST-PS can increase the compatibility in some cases.
Server Signal Response: With this setting the Smart Lock Pro is actively sending keep-alive packages to the Nuki server. If it is turned off only the Nuki server sends keep-alive packages. Turning this feature on can increase the stability of the server connection in some cases.
Important note🚨
Only change the expert settings if the WiFi connection is unstable as any change will impact the Battery consumption and thus can lead to much shorter Battery lifetime‼️
Prerequisites
Smart Lock Pro (4th generation) has installed the most recent Beta (>=4.4.4)
Until now the Energy mode (Settings > Features & Configuration > Battery) was re-used to change WiFi related settings in the background. This controversal UX has now been cleaned up by introducing the above described WiFi Energy Modes and Expert Settings. Resulting the original Energy mode is now mainly reliant to the Bluetooth advertising intervals (again):
Q: I want to use my Smart Lock only local with the MQTT API or Matter integration and do not want it to connect to the internet. What options do i have?
When an internet connection is available the Smart Lock tries to establish a secure, encrypted connection to Nuki servers for automatically downloading the latest firmware updates and updating its time. Without adding additional users with remote access or activating Nuki Web, the server connection can not be used to retrieve the Smart Locks status or to send lock commands. We therefore strongly recommend do not disable this connection.
If you still want to isolate the lock from the internet you have the following options:
Connect the lock to a Thread capable Matter hub that supports remote access via NAT64 and disable remote access for the Nuki app with the “Remote Access” flag on the Matter settings page. You can still use the MQTT API and the Matter integration, but the Smart Lock will not establish a connection to the Nuki servers. If your Lock supports WiFi, make sure that you disable WiFi in the Smart Locks settings in order to prevent a fallback to WiFi. List of compatible hubs.
Connect the lock to your WiFi network and to your Smart Home hub via MQTT. Block in your firewall DNS requests for your lock. This is usually UDP/TCP traffic on port 53. You can also block DNS requests to “*-smartlock.nuki.io” in your DNS server, but this might also result in your Nuki app malfunctioning (e.g. invite creation not working).
Connect the lock to your WiFi network and to your Smart Home hub via MQTT and block outgoing traffic from the Smart Lock to port 443. Smart Locks 4th Gen and Ultra require that the firewall "DROP"s packets while Smart Lock 3rd Gen require packets to be “REJECTED-TCP” (Firewall sends TCP RESET back). If this is not taken care of, the Smart Lock might log on/off the WiFi network (and also disconnect MQTT) frequently!
You can find the IP address of your Smart Lock in the WIFI expert settings of the Nuki App.
Q: I have a Ubiquity UniFi WiFi router. What are the best settings for use with Nuki Smart Locks?
If you have problems with your Nuki products in a UniFi environment we recommend the usage of the “Enhanced IoT compatibility” feature which is described here.
In order to use it, you have to create a separate WiFi network for your IoT devices and turn on the “Enhanced IoT compatibility” flag in the WebUI or the “2.4GHz IoT-Only Mode” in the Unifi app for this newly created network. Afterwards add your Nuki devices to it.
Q: My Android phone fails the security check and I cannot access my Smart Lock remotely. What is the issue?
The Nuki App performs a hardware- and OS-level security check to prevent unauthorized access.
The check contains
Google Play Integrity API: Ensures the OS build is official and meets MEETS_DEVICE_INTEGRITY / MEETS_STRONG_INTEGRITY.
or
Hardware Key Attestation (TEE / StrongBox): Verifies a hardware-level X.509 certificate chain against a list of trusted vendor roots. Example: GrapheneOS without Google play services.
Which Android phones fail the check?
If a device fails the check via Google Play Integrity, Nuki falls back to Hardware Key Attestation. This might fail because the system can’t issue a hardware-backed attestation certificate (e.g. unlocked bootloader) or there are issues with the certificate chain (e.g. CA not trusted, expired certificates contained in chain).
How to still access a Smart Lock remotely:
Smart Home Integrations via Matter or local MQTT API (i.e. Apple Home, Google Home, Amazon Alexa, Home Assistant)
