Smart Lock Wi-Fi disconnects in Automatic mode, stable only in Compatibility Mode – DHCP/ARP evidence
Hello everyone,
I am opening this topic because I have been dealing with a persistent Wi-Fi / remote access issue with my Nuki Smart Lock, and I would like to know if other users are seeing the same behavior.
The short version is:
  • In Wi-Fi Automatic mode , the Smart Lock repeatedly disconnects.
  • Remote access becomes unavailable.
  • DHCP logs show repeated assign/deassign behavior.
  • The device disappears from the ARP table.
  • In Wi-Fi Compatibility Mode , the device remains stable and remote access works reliably.
  • Multiple Nuki devices/replacements showed the same behavior.
  • Another Nuki device from a colleague works correctly in the same UniFi environment.
Setup
My network uses UniFi/Ubiquiti access points.
For testing, I created a dedicated Wi-Fi network only for Nuki:
  • 2.4 GHz only
  • WPA2
  • PMF disabled
  • Fast Roaming disabled
  • BSS Transition disabled
  • Client isolation disabled
  • Band steering not enabled
  • Minimum data rate disabled
  • Multicast/Broadcast blocker disabled
  • MAC filtering disabled
  • No Wi-Fi blackout schedule
  • Standard 2.4 GHz AP configuration
The Smart Lock connects to the Wi-Fi, but in Automatic mode it does not maintain a stable connection over time.
What I see in the logs
On MikroTik DHCP logs, I see repeated events like:
  • DHCP assigned IP to the Nuki MAC address
  • DHCP deassigned IP from the same MAC address
  • DHCP assigned again
  • DHCP deassigned again
At the same time, UniFi shows repeated connect/disconnect events for the Nuki device.
When the issue happens, the device is also not visible in the ARP table, which suggests that it is not simply an app visual issue. It looks like the device is not maintaining a stable Layer 2 / Layer 3 network presence.
Important comparison test
I tested my affected Nuki device in a colleague’s UniFi environment.
His Nuki device works correctly in that same environment without special configuration.
His working device:
  • `09/2025 – 491272—
My affected device:
  • `02/2026 – 4BF955—
My device still showed the same connectivity problem in his network.
This makes it difficult to accept that the issue is simply caused by my own UniFi setup.
Compatibility Mode result
When I enable Wi-Fi Compatibility Mode , the device remains connected and remote access works reliably.
When I switch back to Automatic , the problems return:
  • disconnects
  • remote access unavailable
  • DHCP assign/deassign behavior
  • no ARP entry
  • unstable cloud connection
This strongly suggests that the issue is related to the Smart Lock’s normal Wi-Fi behavior in Automatic mode, possibly power saving, DTIM handling, DHCP handling, keepalive behavior, firmware, hardware revision, or Wi-Fi chipset behavior.
Question
Is anyone else seeing this behavior?
Especially:
  • Smart Lock unstable in Automatic mode
  • Stable only in Wi-Fi Compatibility Mode
  • DHCP assign/deassign loops
  • Device disappearing from ARP
  • UniFi or non-UniFi routers showing similar behavior
  • Differences between older and newer production batches
I understand that Compatibility Mode can help, but according to Nuki it may increase battery consumption. Because of that, I do not consider it a proper long-term solution unless Nuki officially confirms that this is expected and acceptable.
I would appreciate feedback from other users and, ideally, from Nuki engineering regarding what exactly changes in Automatic mode and why Compatibility Mode stabilizes the device.
Thank you.
This FAQ might be helpful for you: Link
Thank you for the link, but the DTIM recommendation is not a new finding in my case.
I have already tested the DTIM-related recommendation before, so the FAQ does not add a new solution for my situation.
The important point is that the issue still happens in Automatic mode, while Compatibility Mode makes the device stable.
In Automatic mode I can see real network-level problems:
  • repeated DHCP assign/deassign behavior;
  • the device disappears from the ARP table;
  • remote access becomes unavailable;
  • the lock repeatedly disconnects from the network/cloud.
In Compatibility Mode, these problems stop and remote access remains stable.
I also want to add an important comparison.
A colleague of mine has a Nuki device purchased on 11/11/25 , and his device does not have this problem. His Nuki connects reliably to different networks, including UniFi and other standard Wi-Fi networks, and it does not disconnect.
In the same UniFi environment where his Nuki works correctly, my affected Nuki device still shows the same connectivity issue.
This strongly suggests that the problem may be related to newer versions, production batches, hardware revisions, firmware behavior, Wi-Fi chipset behavior, or the way newer units handle Automatic Wi-Fi mode and power saving.
So my question is not simply “how do I configure DTIM?” or “how do I enable Compatibility Mode?”.
My question is:
If router-side changes such as DTIM are not sufficient, and the Smart Lock is only stable in Compatibility Mode, is Compatibility Mode considered the official long-term solution?
If yes, what battery impact should users realistically expect?
If no, what is the planned product-side fix for Automatic mode?
Also, are there known differences between older devices, such as units purchased around 11/11/25 , and newer units that could explain why one device connects reliably to any Wi-Fi network while newer/replacement units show repeated Wi-Fi disconnects?
The FAQ explains the workaround, but it does not address whether the Automatic mode behavior is expected, known, or planned to be fixed.
I would appreciate a more specific answer from Nuki regarding Automatic mode stability, not only a link to the general FAQ.
Compatibility mode is something you can permanently use. How big the impact on battery life is, is hard to judge as this depends largely on the network traffic and WIFI interference you have at home.
It’s not about the setting in your router. In the expert settings you determine whether the Smart Lock listens to broadcasts (or ignores them) and whether the Smart Lock wakes up to every dtim beacon or just skips some of them. Compatibility mode also just alters this parameters. So if you work with them you should be able to create your own custom “compatibility mode”.
No. There has been no change in components.
Thank you for the clarification.
It is useful to know that Compatibility Mode can be used permanently.
However, since Compatibility Mode may reduce battery life and the impact cannot be predicted easily, I would like to avoid enabling more changes than necessary.
You mentioned that by using the expert settings, it should be possible to create a custom “compatibility mode”.
Could you please provide the exact expert Wi-Fi settings that are changed by Compatibility Mode, and also a recommended custom configuration that gives the best compromise between stability and battery life?
For example, which settings would you recommend testing first in my case?
  • Broadcast Filter
  • DTIM Skip
  • Server Signal Skip
  • Energy Saving Mode
  • Server Signal Answer
In my case, the symptoms in Automatic mode are:
  • repeated DHCP assign/deassign events;
  • no ARP entry when the issue occurs;
  • remote access unavailable;
  • stable connection when Compatibility Mode is enabled.
So I would like to know which specific expert setting is most likely responsible for solving this behavior.
If the full Compatibility Mode is considered safe for permanent use, that is good to know, but I would still appreciate a more precise recommendation in order to reduce unnecessary battery impact.
Thank you.
I’d try to disable the broadcast filter first. In this case the SL will receive broadcasts and reply to them if needed (such as ARP requests).
If this does not help enable it again and set dtim skip to 0.
If this also does not help, combine both.
Altering the other parameters will most likely not have a relevant impact.
Thank you for the explanation.
I understand the technical reasoning, especially regarding broadcast filtering, ARP replies and DTIM skip. This also matches my symptoms, because in Automatic mode the device disappears from ARP and shows repeated DHCP/network disconnect behavior.
However, from an end-user perspective, this is exactly my concern.
Remote access and stable Wi-Fi connectivity are core features of the product. A normal customer should not have to manually debug expert Wi-Fi parameters such as Broadcast Filter, DTIM Skip, ARP behavior, power saving and keepalive behavior in order to make the lock reliable.
I paid for the product in order to use it, not to debug it or to find manual workarounds for what appears to be firmware/Wi-Fi behavior issues. I understand that advanced settings can be useful for troubleshooting, but they should not become the expected way for customers to make a basic advertised feature work reliably.
I can test the suggested combinations, but this feels more like manually building a custom Compatibility Mode than using a finished consumer product in its default Automatic mode.
Could Nuki clarify why Automatic mode does not automatically adapt these parameters when the device detects repeated disconnects, DHCP renewals, ARP failures or cloud connectivity loss?
For example, if the Smart Lock detects that it repeatedly disconnects or loses remote access in Automatic mode, could the firmware automatically adjust Broadcast Filter / DTIM Skip behavior, or at least show a clear recommendation in the app?
I am willing to test the settings, but I think this should be handled by the product/firmware automatically, not by customers through trial and error.
Thank you.
As an end consumer please choose “Compatibility mode” and everything is fine. This is why it exists in the first place.
This is a developer forum and you asked for more details and got more details.
I understand that this is a developer forum, and I appreciate the technical details you provided.
However, my concern remains that Compatibility Mode is presented in the app as a mode that significantly increases battery consumption. So from a customer perspective, “just use Compatibility Mode” is not exactly the same as “everything is fine”, unless Nuki officially considers the increased battery consumption acceptable for permanent normal use.
If Compatibility Mode is the recommended permanent solution for end consumers in this situation, then that is useful to know.
Could Nuki please clarify one final point:
Is the official recommendation for users affected by this Automatic Wi-Fi instability to use Compatibility Mode permanently, accepting the reduced battery life?
If yes, then I will continue using Compatibility Mode, but I think this should be communicated more clearly in the app/support documentation, because the current wording makes it sound like a last-resort workaround rather than an official long-term operating mode.
Thank you.
Yes
Thank you for the feedback. We’ll take it into consideration and rethink the wording.
