Environment:
- Lock: Nuki Smart Lock Pro (5th Gen), replacement unit restored via backup. (Previous identical lock worked fine via Matter with Alexa earlier this year prior to Alexa+ transition).
- Thread Border Routers: Amazon Echo Show 11 (4.5 m direct line of sight) & 2x Echo Studio (2–3 m). SwitchBot Hub (Matter over Wi-Fi) is working fine in the same network.
- Router & Clients: FRITZ!Box 5690 Pro (IPv6, ULA, DHCPv6 IA_PD, “Allow IPv6 prefixes announced by other IPv6 routers” and Wi-Fi client communication enabled). Tested Alexa App on Samsung S25 Ultra, Galaxy S23, and iPad (iPadOS 26.2).
Issue / Proof that Echos do not send BLE requests:
- Put Nuki into Matter pairing mode via Nuki App (solid white LED ring; normal “unlocked” blinking is disabled in settings).
Starting Matter setup inside the Alexa App (tested via QR code & 21-digit manual code, both via “Nuki” and “Other → Matter”) results in a timeout. The LED ring stays solid white the entire time — no BLE connection attempt reaches the lock from the Echos.
Counter-proof via OS popup: When triggered via the Android/SmartThings OS popup, the phone immediately initiates the BLE handshake with the lock (solid ring turns off, top segment blinks). It only fails afterwards with “Thread Border Router required” because Amazon locks its Thread credentials inside Google Play Services.
Already tried without success:
Built-in Wi-Fi disabled on lock, BLE set to “Performance”, 10s soft reset on lock, force-stopped Nuki App / disabled phone BT during iPad test, disabled Nuki Skill in Alexa, disabled Android Nearby Scanning, rebooted FRITZ!Box & Echos, unplugged non-Thread Echos (Echo Flex), tested 2.4 GHz-only Wi-Fi.
Question: Is this a known BLE advertising incompatibility with current Echo firmware (Alexa+), or can my Lock ID be whitelisted for Firmware Beta 5.10.2 to test if it resolves the commissioning issue?
