Smart Lock Pro (4th gen) - Matter “Open door” (UnboltDoor) not advertised in DoorLock FeatureMap
I use a Nuki Smart Lock Pro (4th generation), firmware 1.4.1, commissioned via Matter over Thread into Home Assistant 2026.10.0 (Matter Server 1.4.0).
Problem: Home Assistant does not offer the “Open door” action for this lock, only lock/unlock. The lock entity reports supported_features: 0.
What I found in the Matter diagnostics (endpoint 1, cluster 0x0101 DoorLock):
FeatureMap (1/257/65532) = 0, so the Unbolt feature (bit 0x1000) is not advertised.
However, the AcceptedCommandList (1/257/65529) contains command 39 (UnboltDoor).
So the lock seems able to execute UnboltDoor but does not declare the feature, and the controller therefore hides the action.
Why it matters: when the door is locked with the key from outside, the Nuki app shows the lock as open, and “Unlock” (from the app or Home Assistant) jams the motor. Only “Open door” from the Nuki app works. I would like the same action from Home Assistant.
Already tried: reload of the Matter integration, Matter Server restart, full HA restart, and setting the app swipe actions to “Open door”. No change.
Questions:
Should the Smart Lock Pro advertise the Unbolt feature in FeatureMap on this firmware?
Is there a setting or firmware version that enables it?
I can provide the full Matter diagnostics file if useful.
Thank you.
NUKI gen 4
To open the door with HA when it has been closed from outside with a key
My Nuki is configurated with a handle outside; because … I have a handle outside; my problem is when someone goes outside and lock with a key==>in that case, “open” does not work , because Nuki considers the lock as “still open”
OK ; is there any drawback to set up NUKI APP with a knob outside (while I have a handle ) ? ==>does it means that the APP will always apply “open the door” ? ; is there a possibility to display both options on the APP (home assistant): UNLOCK and OPEN the door ?
The default option within the Nuki app will be “Open” then yes.
You’ll need to tap on the lock and slide up the bottom sheet to show the “unlock” option.
If this is not convenient for you the only solution to have the “Unlatch” option within Home Assistant is to use the MQTT integration.
