Same webhook fires multiple times
Hi!
I am using advanced API to setup a webhook for log update. The problem is - the identical webhook message firing multiple times. Please, advise.
Hi @Alexander_Futoryan !
Could you give me details from the Webhooks log (in Nuki Web) on what exactly is sent multiply times?
Hi!
Here is example from today - the only difference is timestamp:
“headers”: {
“X-Nuki-Signature-SHA256”: “6bcf69e25dc95dfa6683c044b6e5ce403927c6c51f28e5cb78907ac55853f2a1”,
“X-Nuki-Signature”: “f83f5bfe0d9a6cbd91c69a1e9b330a53e13cdf74”,
“Content-Type”: “application/json; charset=UTF-8”
“body”: {
“feature”: “DEVICE_LOGS”,
“smartlockLog”: {
“id”: “6103a7678519f22bd7ca86bb”,
“smartlockId”: 618373060,
“deviceType”: 0,
“authId”: “5ffc6263396b571f557de420”,
“name”: “Sunny”,
“action”: 3,
“trigger”: 0,
“state”: 0,
“autoUnlock”: true,
“date”: “2021-07-30T07:16:55.000Z”
“timestamp”: “2021-07-30T07:16:36.821Z”,
“path”: “XXX”
  "headers": {
    "X-Nuki-Signature-SHA256": "6bcf69e25dc95dfa6683c044b6e5ce403927c6c51f28e5cb78907ac55853f2a1",
    "X-Nuki-Signature": "f83f5bfe0d9a6cbd91c69a1e9b330a53e13cdf74",
    "Content-Type": "application/json; charset=UTF-8"
  "body": {
    "feature": "DEVICE_LOGS",
    "smartlockLog": {
      "id": "6103a7678519f22bd7ca86bb",
      "smartlockId": 618373060,
      "deviceType": 0,
      "authId": "5ffc6263396b571f557de420",
      "name": "Sunny",
      "action": 3,
      "trigger": 0,
      "state": 0,
      "autoUnlock": true,
      "date": "2021-07-30T07:16:55.000Z"
  "timestamp": "2021-07-30T07:16:36.538Z",
  "path": "XXX"
O.k., thanks for the update (you can also remove details on the device or send via PM ):
It clearly looks like the same log entry has been sent twice. We will investigate on this!
EDIT: Already removed your Webhook URL from the post.
thanx! forgot we’re on public forum. I will be more careful next time,
Hi!
I’ve got exactly the same problem. Every webhook is sent twice. Do you have any results from your investigation?
Thanks and best regards,
Ben
